enable cli space-completion
Description
Enables the ExtremeXOS feature that completes a command automatically with the spacebar. The [Tab] key can also be used for auto-completion.
Syntax Description
Default
Disabled.
Usage Guidelines
CLI space auto completion cannot be enabled while CLI scripting is enabled with the enable cli scripting command.
The following command enables using the spacebar to automatically complete a command:
Platform Availability
